AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
New AutoCAD Plant 3D content pack and hot fix are available now
8 REPLIES 8
Message 1 of 9
oscar_santillan
1149 Views, 8 Replies
I download the structural steel section content pack for australia.  This is the file "Structural Catalog.acat"
My question is, how I add this file to the autocad plant 3d software, to use it?
8 REPLIES 8
Message 2 of 9
ybogdanov
in reply to: oscar_santillan
De donde eres Oscar? Te puedo ayudar. Tienes que copiar el fichero en la carpeta Common en el sitio donde tienes todos los catálogos, por defecto C/AutoCAD Plant3D Content Folder
Un saludo
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 3 of 9
Hi, i solve that problem thanks.
I would like if you can tell me, because I added a new content pack with piping and fitting, and one of them has not the size I want for example DI class 150 start on 350 diam, and I want from 50 diam up, can you tell me if I can resize one of them to the size I want for example 350 diam to 100 diam. I know I can do it but I dont know where I have to go, I tryed but I only see pictures of the flanges for example. I appreciate if you can tell me where I have to go into the autocad Plant 3d softwere to change it?
I am living in sydney, australia and you?
Oscar
Message 4 of 9
I give you my email address if you have some answer, is quicker that this site
oscar_santillan@live.com.au
Message 5 of 9
Perdon no me di cuenta que hablabas espanol
Message 6 of 9
There is a readme file associated with each of the content packs that explains where to place the file.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Message 7 of 9
I need your help please, please.. I Can't find the steps how to open Georg Fischer III content pack in my AutoCad plant3D 2013. How to export .pcat catalog to AutoCad.? I need to draw PE pipes, 1.) I copied all ( Georg Fischer III content pack) pcat files to destination (AutoCAD Plant 3D 2013 Content/CPak Common) as discribed in readme. 2.) Then I run the Acad Plant3D but I can't find PE pipes in there (in spec selector). Could you please explain me, what is wrong? how to integrate Georg Fischer III content to AutoCadP3d 2013, I attached small video file to show how i do that. Help me.....
Message 8 of 9
You are correct in placing the catalog in the \Common\ folder, but you need to make a Spec from it. What you downloaded was the Catalog. A Specification is a specific filter of parts from a catalog. A process engineer or the client will be able to tell you whats in the spec to be used on your particular project.
Once you have made the spec, you then put that spec in the \Specs\ folder of your project, then anyone working on the project will be able to see it
Tomislav Golubovic
Message 9 of 9
keithg1001
in reply to: raimondas1222
Dear Raimondas1222,
Did you manage to resolve the issues of finding the PE pipes in Spec Editor? I am having exactly the same problem I think, I downloaded the Content Pack into the CPak Common folder, but cannot find the catalogue from which to make a spec. Any assistance would be greatly appreciated. Regards, Keith.
”Boost
