AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Need Lisp to Change Layers of All Nested Objects back to "0"
1 REPLY 1
404 Views, 1 Reply
I am trying to find a Code that change the “internal blocks and lines” of a Block back to;
Color -                             ByLayer
Layer -                             0
Linetype -                         ByLayer
Linetype Scale -                1.000
Lineweight -                     ByLayer
Transparency -                  ByLayer
Thinkness -                       0
This way when I change the Main Layer of a block to Another Layer with a Different Color, all the internal blocks will change to that color too.
1 REPLY 1
KenFauver
You may want to post this into the AutoCAD only forum.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
”Boost
