I am trying to reconfigure the sequence of the line info. on our ISOs. It currently comes in "Pipe line #, size, spec". We want it to be "size, service, line number, spec". The service doesn't even show up now. I've found in the isoconfig.xml where I would modify this but I don't know how to exactly. I've tried a few things but nothing is working for me. Does anyone out there have any idea how to get this to work? Thank you in advance.
Solved by dave.wolfe. Go to Solution.
Hi Dave,
Thank you for the solution. I haven't done it yet, but I just recently took the advanced P3D class up in Baton Rouge with Aaron Simson and we did discuss the Plantdefinecalcproperties. I was just about to start looking at this when I received your email. I also just want to tell you that your book that we used in the class is by far and away the best class guide I have ever used. Lots of examples, explanations and links. I have been to many, many CAD classes over the years and I must say, you did a fantastic job with it.
Thanks again, E
Thank you!
