AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
navisworks version
5 REPLIES 5
evadmoore
703 Views, 5 Replies
navisworks version
How can I tell if naviswoks service pack 2 is loaded on my PC?
Does it have a different version number?
This is what it shows now.
Version 11.6.0.114420
Built Jun 19, 2014
5 REPLIES 5
pvillella
in reply to: evadmoore
Bump thread.
Can someone at Autodesk reply to this? I've got the same question as original poster.
Navisworks isn't consistent with other Autodesk products when it comes to reporting service packs. It doesn't tell us what service pack is installed, as in SP1, SP2, etc. when you go to About.
Instead, it simply shows a build number. This doesn't mean anything to us unless you post what build corresponds to what SP.
It is especially important that firms that share a year version of Navisworks are using the same service pack of that year. So, it's even more important to make it easy for a person to know whether they've got the correct SP installed or not.
We have 2 service packs in our deployment and I want to make sure they are getting applied correctly.
Can someone verify that
Built Jun 19, 2014
is HF3 for Navisworks?
Thank you,
Patrick  Villella, LEED AP
AEC Technical Consultant
_______________________________________
www.cadsoft-consult.com
Blog: What's the Word on BIM? www.cadsoft-consult.com/blogs/architecture
dgorsman
in reply to: pvillella
Think I saw something about this in the Navisworks board.  From what I remember, this has been picked up by the developers and will be implemented in future releases.  I'd still check the next BETA release and ensure it has been implemented.
From what I can tell, Navisworks SP's *do* show up in the control panel when looking at installed updates.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
DarrenP
in reply to: dgorsman
with navisworks 2015 sp1 this was fixed
DarrenP
pvillella
Thank you dgorsman. For the 2014 products, I don't see Navisworks SPs listed in Program Files (via Control Panel). Do you?
pvillella
in reply to: DarrenP
Thank you DarrenP. I'm very glad to hear this has been changed in 2015. I'm working with a client still using 2014 right now, but this change will make things easier down the road.
”Boost
