AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Multiple title blocks Ortho Templates
2 REPLIES 2
sergej_dezelak
662 Views, 2 Replies
I have several title blocks for orthogonal drawings (A0, A1, A2, A3, A4). But when I put path in project manager for Ortho template (dwt) there is only one path.
How can I create all this template and than choose which one I want to use?
2 REPLIES 2
jabowabo
in reply to: sergej_dezelak
You can create folders in the Project Manager palette on the 'Orthographic DWG' tab by right-clicking a tree item.  When you create a new folder, you can select whichever template you want to use for drawings that are to be created within that folder or check 'Prompt for Template'.  You could create a folder for each size if you like.
sergej_dezelak
in reply to: jabowabo
Thank you for this solution. That is exactlly what I need.Smiley Happy
”Boost
