AutoCAD Plant 3D Forum
Multiple line text wrapping on Equipment tags in P&ID
4 REPLIES 4
AarTomas
2207 Views, 4 Replies
Essentially the problem is that some of my equipment tags are too long.
And it would be better if they could be automatically formatted to something more like...
It needs some text wrapping to make it two (or more) lines.
I tried editing the annotation block in the block editor, in the Project manager. Specifically enabling the "Multiple lines" option in the Attribute-Misc section, and choosing a reasonable boundary width of 30.
But it doesn't seem to affect the tags.
Any help/suggestions/tutorial steps would be appreciated!
4 REPLIES 4
dave.wolfe
in reply to: AarTomas
First, you might have better success on the P&ID forums. In any case, try choosing the boundary width manually, I did that and the wrapping worked for me.
Final result
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
AarTomas
in reply to: dave.wolfe
Thanks for the tip! I'll post there next time.
As for the wrapping, it seemed as though I was doing exactly what you were doing. So then I checked through the links and it turns out that whoever set up the tags linked them in such a way that I was editing a slightly different block than the one that was being displayed.
I got it wrapping on a new tag so now I'll just see if I can get it working on the one that's being displayed. i.e. finding the block somewhere in the Project manager, it's linked as "New Filter Tag_Block" but I have a feeling it's some weird internal addressing.
Thanks!
RichO
Ok, Ive been doing this and it works to a degree, however it would be nice to be able to adjust the width of the multi line for different tags, as the line justification for some text is a not so good
 It would be good to be able to adjust the width for individual labels via the properties pallette
I can adjust the length of the line manually by turning on show properties (3rd pic) if value shown in 2nd pic is adjsuted then the line length adjusts (fun but pointless)
would be good if we could make the boundary width shown in pic 1 visible and adjustable via the properties pallette in the same manner
target width to be shown in properties pallettetarget width to be shown in properties palletteexample of off justification for next lineexample of off justification for next lineShow Properties.JPG
dmichaels
Trying to set this up in Plant 3d P&ID tags.  Would like the tag to word wrap WITH underline, but when adding %%U to the tag, that is what actually shows(%%UTAG)(#2 in screenshot) instead of the TAG being underlined. If i don't set the word wrap ruler manually then it doesn't wrap at all and puts tag all on 1 line with the underline(#1 in screenshot). Does anyone have a workaround or resolution for this issue we are having, any help would be much appreciated. Thank you.UTAG.jpgUTAG2.jpgUTAG4.jpg
”Boost
