I have an issue where i need two different sizes of gaskets in my model, when i try and substitute one for the other, it completely disappears and shows the leak symbol. I need to be able to either
1. switch gaskets, or
2. find a way for both gaskets to come in in their proper connections.
Is it possible to set up a connection to automaically bring in the correct gasket?? (i.e. rubber linning using one gasket, and HDPE use another gasket in the same spec.)
Bump!
I too have this same problem, and would love to know if it's possible to use multiple gaskets (and bolt sets). I have a flange and a union in the same spec, and despite having different "facing" that coincides with the facing on the seperate gaskets, both flange and union automatically use the same gasket. Any ideas anyone?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Best Regards,
Pat Andres
GHD Manila
Friends,
I am also facing same situation at my end and trying to solve this.
As we can select Different BOLTset from single spec, is it possible to select gaskets also?
It is just raw suggestion . I have already tested but not getting success.
as I am new to AP3D, I thought to take expert advice.
Best Regards,
Pat Andres
GHD Manila
i dont believe you ...
maybe you have different desctiptions but not different thicknesses
@ Dear All, you can fixed it using connection setting use gasket std property in catalog and same should be match in connection setting.
