I recently had to move my model to get the North/West coordinates to match the field. Before I moved the model I was getting good isos using iso by line number. After I moved the model when I iso by line number it gives me 2 identical sets. Any ideas how to fix this?
Solved by mark9765. Go to Solution.
that means that there are two lines present in your model. Maybe a copy?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Thanks for the reply but I figure out what is going on. There was another model in the project under a different name. When I did an iso it pulled the line number from both models. I removed the extra model from the project and the problem is solved.
Good for you. Happy holidays mate.
Best Regards,
Pat Andres
GHD Manila
