AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Moving from CadWorx to Plant 3D deal breaker. Can somebody confirm this please?
9 REPLIES 9
Message 1 of 10
PatrickByrne
2006 Views, 9 Replies
I am restarting this thread from “Attach standard valve size to non standard size pipe” thread, I need to know if this can be done as it might decide whether we move from CadWorx to Plant 3D.
I believe this cannot be done.
For example I need to connect a DN300 valve to a DN315 pipe, I have been told previously by the Plant Expert all I need to do is unrestrict the diameter setting for the flanged connection, I tried this to no avail. I have also tried changing all connections to None in both Required and Optional matches, I still cannot make this connection.
I believed that by changing all connections to None I should have been able to connect a DN300 valve to a DN150 flange but it is still picking up the nominal diameter from somewhere.
9 REPLIES 9
Message 2 of 10
dave.wolfe
in reply to: PatrickByrne
So you can do it on a limited basis with matching values.  You may need to create a duplicate joint setup for the default values.  When you insert the value, it will assume the size of the line, but with this setting I was able to switch the size of a value in a 6" line to 4" without errors.
Out of curiosity, why is this such a big deal?  What is the purpose behind inserting out of size valves?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 3 of 10
Are you talking poly pipe?
315 OD PE pipe is NOT DN315
It is DN300 but in australia we call it up as 315 OD (there are a couple of distributor catalogues that call it DN315, but this is not actually right)
These connections CAN be made...but there is a bit of setup and messing around to do.
I tried to hint to the 'expert' you asked but he was too arogant to consider the implications of my comments and obviously had zero experience with this type of piping system.
the matching values method did not work when i was setting this up a year ago
but 2013 may have other options
Ive been doing mechanical stuff for the last 12 months so my plant knowledge has gone a little rusty and Im under the pump for project deliverables atm
I think Tomislav may have some info on how to set this up.
Message 4 of 10
PatrickByrne
in reply to: dave.wolfe
Sorry I am not getting it here, which joint connection have you added the matching size data to?
It is important to us because we use a lot of piping that has different size flanges to the nominal size of the pipe similar to HDPE. For this to be correct we use standard valve sizes.
We have cases were we go from a DN150 pipe which has DN200 flanges to a DN200 valve to a standard DN200 steel pipe.
Message 5 of 10
PatrickByrne
Hi Richo,
What do you do with the other Poly sizes 180, 200, 225, 250, 280, 300. I was waiting for Tomislav to get back with an answer but he has not at this stage.
Message 6 of 10
dave.wolfe
Yea, I have 0 experience in this area, but I think I may have a workable solution.
You can modify your flanges to use a smaller matching pipe od.  Then, create a joint that uses the matching pipe od instead of the nominal diameter.  The flanges come in at the line size, but you can switch it to the next size larger after the fact.
Joint setting for matching pipe od
Special flange with smaller matching pipe od
Large flange on a pipe that a valve can be placed on
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 7 of 10
PatrickByrne
Thanks everyone, I will give Dave's solution a go on release 2013, I could not get it to work on 2012 and get back to you. It is the most eloquent solution.
Another solution was to put in the pipe and flange, then add the valve to another area of the drawing. I can then move the valve to the flange and the use the connect to adjacent command.
For Autodesk I would like to know why when you unselect Nominal Diameter for all connections it still selects the Nominal Diameter when adding in the valve.
Message 8 of 10
i think i set it up something like
item or pipe size was DN150 but in the description I called it 160 OD, SDR17, PE100, ....
or 180 OD, ....
with the 160 as the default, then you just use the triangle to change to 180 if thats the one you want
It wasnt perfect but it worked, I was in discusions about how to get the matching values thing to work but that was when 2012 just came out and I havent had the time to revisit
Message 9 of 10
PatrickByrne
Thanks once again Dave.
I set up a new end type and added that to the valves, I also matched the pipe OD for the flanges and the valve to the size of the flange. Therefore I can bring in the valve and mate it up to the flange without having to connect to adjacent.
Message 10 of 10
KenFauver
Good solution Dave. Thanks for the help.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
”Boost
