In Plant 3D 2015 there is a dialog box that shows up when you hover over a piece of pipe that gives you a little information ie. spec size line number etc.
My question is, can I edit something somewhere to have this dialog box give me more information? Or different information if I wanted? What I really want is a quick way to determine bottom of pipe elevation or center of pipe elevations. Right now, the fastest way I can think of to do it, is to select the line and open properties, then scroll down to where it gives you that information.
If anyone has a better way but does not know how to edit the dialog box, please go ahead and share it here. Thank you all.
Kyle
Solved by jabowabo. Go to Solution.
Looks like pipe elevations are not available for rollover tooltips:
If you turn on DYNamic input you can see the elevations when you select the change elevation grip:
