AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Modifying Annotation Layers of an Iso Theme
1 REPLY 1
Chavez79
464 Views, 1 Reply
I have modified the isoconfig file so that I now have additional Iso Components in my Default Theme. The problem I'm having is figuring out how to get the theme to recognize the items I want on those components. All of the part numbers, Spool numbers and Iso Notes fall under annotations and get assigned the ISO Text layer the way I currently have it set up. I want to have the Part Numbers be on Layer ISO_BOM and Spool Numbers to be TA2015 as seen in my attached image. Has anyone ever tried to redefine the items that are lumped under annotations?
Thanks for any input.
1 REPLY 1
Have you had a chance to refer to Isometric Configuration (Advanced) in Plant 3D 2014? However, it appears that you might be using an earlier of version of Plant 3D. If so, this link still has some useful information that might help.
http://docs.autodesk.com/PLNT3D/2014/ENU/filesPLNT3D/GUID-4923622A-F06C-4EA9-AE21-F3E4CAC841A4.htm
If possible, please attach a screen capture of where you made the changes in the XML that shows where you added your Iso Components.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
”Boost
