What program is in this manual (attached pdf)? I cannot find any program with name "symbols editor". Is from Autodesk?
Halo...
Software that You see in this PDF file is Symbols editor that is standard part of installation of "Alias Piping Solution" program called I-Run...
take a look
(http://www.alias.ltd.uk/whatisi-run.asp)-not for advertising just for information
Look this PDF, it contains all symbols that are in ISOGEN:
I am using Plant 3D 2013 and am having trouble outputting weld tables. I am using a number of different welds from buttweld to socket weld and fusion weld. I have a problem with the fusion weld as it is picking up the symbol of the socket weld when I want it just to be a 'dot' on the iso like the buttweld.
I have tried changing the symbol and have even tried this on a local test project and the fusion symbol is still picking the glued/socket weld symbol. Visually everything is mapped but I do not understand why it is still picking up the different symbol.
I am ok if the fusion symbol is different but the problem is that it will not create a weld list which is what I require. The buttweld etc. can automatically create the weld list and annotate each weld in the iso but how can a weld symbol be told to produce and annotate the weld list.
Any help would be greatly appreciate
Many thanks
Lance
