AutoCAD Plant 3D General DIscussion
Member
0 Kudos
Post 1 of 5
Modification Nozzles
331 Views, 4 Replies
09-10-2012 08:19 AM
I'm inserting equipment (tanks) and I get the nozzle with a flange type WN.
How can you change the type of nozzle flange SLIP-ON?
8 Kudos
Post 2 of 5
Re: Modification Nozzles
09-10-2012 01:09 PM in reply to: jmiguell
You have to Add First in Your Spec File and it will be a bear in Edite Nozzle
Ahmed Helal
Member
0 Kudos
Post 3 of 5
09-11-2012 07:53 AM in reply to: Ahmed1081975
I could send the steps to add the Nozzles to spec
thanks
8 Kudos
Post 4 of 5
09-11-2012 09:44 AM in reply to: jmiguell
Here you are in the attached files
Ahmed Helal
Valued Mentor
65 Kudos
Post 5 of 5
09-11-2012 03:15 PM in reply to: jmiguell
in 2012 you may need to edit the file 'NOZZLE Catalogue.acat'
it will be under your 'CPak Common' folder
in the catalogue editor, when you go to the open dialogue box, just pick the *.acat from the 'files of type' drop down box.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
