AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Modification Nozzles
4 REPLIES 4
jmiguell
531 Views, 4 Replies
I'm inserting equipment (tanks) and I get the nozzle with a flange type WN.
How can you change the type of nozzle flange SLIP-ON?
4 REPLIES 4
Ahmed1081975
in reply to: jmiguell
You have to Add First in Your Spec File and it will be a bear in Edite Nozzle
Ahmed Helal
jmiguell
in reply to: Ahmed1081975
I could send the steps to add the Nozzles to spec
thanks
Ahmed1081975
Here you are in the attached files
Ahmed Helal
in 2012 you may need to edit the file 'NOZZLE Catalogue.acat'
it will be under your 'CPak Common' folder
in the catalogue editor, when you go to the open dialogue box, just pick the *.acat from the 'files of type' drop down box.
”Boost
