AutoCAD Plant 3D General DIscussion
Employee
rajsekarpillai
Message 11 of 17 (333 Views)
Re: Modeling up custom fittings
05-21-2012 08:25 PM in reply to: JohnHolder
Just want to confirm with you that your new partfamily is on right class hierarchy? It should be “Olet” class and subclass should be “Weldolet” or “Sockolet”.
Please pass your excel sheet or snap shot, I will look into it.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Valued Mentor
JohnHolder
Message 12 of 17 (322 Views)
05-22-2012 09:58 AM in reply to: rajsekarpillai
I do not see a subclass area.
I am not using excel, just the AutoCAD Plant 3D Spec Editor 2013
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Valued Contributor
Arch_art
Message 13 of 17 (273 Views)
09-26-2012 03:35 PM in reply to: rajsekarpillai
I have successfully create the saddle. Problem is, it doesn't recognize the flow of the pipe. How can I let it behave like pipe support? Pipe support only one connection point on pipe run, but still recognize the direction of the pipe run. Look at the image.(I like the one on left knows the flow of pipe and insert it like the one on right.)
Cheers,
Peggy
Valued Contributor
Arch_art
Message 14 of 17 (271 Views)
09-26-2012 03:36 PM in reply to: JohnHolder
Hi, John
Have you find the answer?
Cheers,
Peggy
Valued Contributor
Arch_art
Message 15 of 17 (263 Views)
09-26-2012 06:43 PM in reply to: rajsekarpillai
No worries. I got it to work now.
When create the block, just need to make sure the direction you want to match the pipe is parrallel with X axil. If it is match with X, the pipe run will be correct.
Am I right? Or I am just accidently correct? Please confirm.
Cheers
Peggy
Valued Contributor
Arch_art
Message 16 of 17 (260 Views)
09-26-2012 06:44 PM in reply to: JohnHolder
Hi, John
I found it, the subtyle is in the General Properties tab after you created the component. Not when you create the component.
Cheers,
Peggy
Active Contributor
btrevena
Message 17 of 17 (89 Views)
04-15-2014 08:58 PM in reply to: Arch_art
Hi John,
This has been on my list of ToDo things for a while.
We have Clamp-On Victaulic branch connections (Reinforcment Saddles in PE) that behave like an Olet.
Victaulic, PVC and PE Catalogues.
See video link demonstrating placement in 3D model.
https://www.youtube.com/watch?v=bifudfTfbO0
Please contact Cadgroup for workflow instruction and/or content.
Contact details on video intro slide.
Bruce
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
