AutoCAD Plant 3D Forum
Modeling up custom fittings
16 REPLIES 16
Message 1 of 17
JohnHolder
1237 Views, 16 Replies
I am trying to figure out the easiest way create a saddle ( for sch 40 pvc )
I have it modeled up, converted to a block.  the first time I made it into basically a Tee with 3 connection ports (with plantpartconvert ) two horizontal with 0 spacing and the reduction connection port vertically - like a Tee
but when I place it, it cuts the pipe in the center, which I would like to avoid.
it would be basically an Olet but wrapping directly around the pipe.  When creating a block based component
how many ports should an Olet have? and what would the behaviour be attaching to a pipe length?
I've never had any luck using the plant 3d parametric graphics, and I have all the fittings already modeled from when I didn't have P3D.
Just looking for a different perspective on this.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
16 REPLIES 16
Message 2 of 17
jason.drew
in reply to: JohnHolder
Hi John,
Are you using AutoCAD Plant 3D 2012 or 2013?
Also, are you needing a pipe saddle or a reinforcement pad?
2012 does not support pipe saddles/reinforcement pads (although there might be a way to use a modified olet to place it on a line)
2013 supports reinforcement pads natively:
http://autocad.autodesk.com/?nd=plant2013newfeatures
Jason Drew
Designated Support Specialist
Message 3 of 17
JohnHolder
Pipe saddle. As in an bolted on tee
Master Yoda.
Message 4 of 17
JohnHolder
I see what you mean by reinforcement pad, but can I have that show up as a saddle in the BOM?
http://www.spearsmfg.com/prod_brochures/COS-2-0804_0610_web.pdf
 Also using 2013 now.
Master Yoda.
Message 5 of 17
JohnHolder
Also - any Ideas why the catalog builder keeps telling me no excel? ( when it is installed )
Master Yoda.
Message 6 of 17
jason.drew
Hi John,
I'm currently checking into this issue and will let you know what I find out.
Thank you,
Jason Drew
Message 7 of 17
jason.drew
in reply to: jason.drew
My first recomendation would be to reinstall Microsoft Office and then see if Plant 3D finds it. I've never ran into an issue where Plant 3D doesn't detect that MS Office is installed.
What version of Office are you using? I believe Office 2003 - 2010 is supported, but I've never tried using older versions.
Thank you,
Jason Drew
Message 8 of 17
JohnHolder
So to continue,
trying to make a pvc pipe saddle (eg. http://www.spearsmfg.com/prod_brochures/COS-2-0804_0610_web.pdf )
I am using the olet base parameter.
what does the <End Type> need to be for the main pipe run? and for the reduction side I am using PSW.
currently I am just using PSW for both and it seems to work, but the pipe is not "connected"  there is no red line when you select it as with properly connected pipe.
for one of the fittings the connection port properties I have 24 inch for the P1 ( pipe run ) and 12 inch for the P2 ( reduction )
Master Yoda.
Message 9 of 17
rajsekarpillai
We recently posted Spears Sch 40 catalog in Plant Exchange and please have a look.
Split Saddle we don't support in parametric shape.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Autodesk, Inc.
Message 10 of 17
JohnHolder
in reply to: rajsekarpillai
yes I know but the question was
the split type saddle is irrelevant since olets have 2 connection ports one connects to the main run and one is the split.
I wanted to know what end types both are if I was using parametric design, so I can use the same type for my custom graphics.
Master Yoda.
Message 11 of 17
rajsekarpillai
Just want to confirm with you that your new partfamily is on right class hierarchy? It should be “Olet” class and subclass should be “Weldolet” or “Sockolet”.
Please pass your excel sheet or snap shot, I will look into it.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Autodesk, Inc.
Message 12 of 17
JohnHolder
I do not see a subclass area.
I am not using excel, just the AutoCAD Plant 3D Spec Editor 2013
Master Yoda.
Message 13 of 17
Arch_art
I have successfully create the saddle. Problem is, it doesn't recognize the flow of the pipe. How can I let it behave like pipe support? Pipe support only one connection point on pipe run, but still recognize the direction of the pipe run. Look at the image.(I like the one on left knows the flow of pipe and insert it like the one on right.)
Cheers,
Peggy
Message 14 of 17
Arch_art
Hi, John
Have you find the answer?
Cheers,
Peggy
Message 15 of 17
Arch_art
No worries. I got it to work now.
When create the block, just need to make sure the direction you want to match the pipe is parrallel with X axil. If it is match with X, the pipe run will be correct.
Am I right? Or I am just accidently correct? Please confirm.
Cheers
Peggy
Message 16 of 17
Arch_art
Hi, John
I found it, the subtyle is in the General Properties tab after you created the component. Not when you create the component.
Cheers,
Peggy
Message 17 of 17
btrevena
in reply to: Arch_art
Hi John,
This has been on my list of ToDo things for a while.
We have Clamp-On Victaulic branch connections (Reinforcment Saddles in PE) that behave like an Olet.
Victaulic, PVC and PE Catalogues.
See video link demonstrating placement in 3D model.
https://www.youtube.com/watch?v=bifudfTfbO0
Please contact Cadgroup for workflow instruction and/or content.
Contact details on video intro slide.
Bruce
”Boost
