I have recently started using custom blocks to add electric actuators to various valves in a project I'm working on. For awhile it was working fine however now the valve blocks are no longer displaying the actuator. It seems as soon as I delete the original block that these valves were using to show the actuator it will remove them from the valves if I close and reopen the drawing. Keep in mind I have not purged the block from the drawing just deleted the physical block. I would assume that I shouldn't have to keep a block in the display just so that the other valves work right. If I am wrong I recommend a fix for this in the next release.
Just to clarify, are your actuator blocks in P&ID or Plant? Are you using 2013? Do you have any before/after screen shots you can share?
Quentin Contreras
Technical Support Specialist
The problem I'm having is in Plant 3D. Attached is a picture that shows one valve without it and one with the actuator. I have since started to reselect the blocks so that it shows again. If you notice I highlighted what properties says when you select the one that does not show the actuator.
Aaron
The Block In Plant Not P&ID, how it will be in p&id And my screen shot saw the generated isometric?
Ahmed,
There is no P&ID for this job I am simply modelling piping for coordination. Well there is a P&ID but it wasn't created with Autodesk P&ID, just regular AutoCAD. If I were to do it in AutoCAD P&ID it would just be a control valve. What I am trying to do is just attach a 3d block of the actuator (in this case a rotork actuator) via the valve operator dialogue box. See attached image for clarification of what I'm clicking on in a 1, 2, 3 step sequence.
