AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Mirrored new Iso symbol (with new end type)
5 REPLIES 5
serafin.albiero
1543 Views, 5 Replies
Greetings All !!
Please help! I have a problem with one of my custom iso symbols. I have tried this solution but unsuccess:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Iso-Symbol-Works-Sometimes/m-p/3624432#M7063
I have created a new end type TC for Port 1 (S1), and:
- Port 2 (S2): BV
- Symbol Type: FLANGE
- Symbol SKEY: My mapped skey symbol, aka MNDT
- Component Category: Flange (Welding neck flange)
See images:
New End Type
Symbol Block with FlipY parameter and Flip1 action:
The isometric with mirrored TC Niple symbol, 3D (green box) ok:
What am I doing wrong?
Thanks in advance!
P3D 2013.
PS.: If I change Port 1 (S1) to FL, isometric generates succesfully with no mirrored symbols!
Serafin A. Albiero Jr.
Tags (2)
5 REPLIES 5
Dear Autodesk Supports
I have Issue in isometric symbol new created for more than 2 ports pleas find the attached photos for more clarification
in my issue please it's very urgent
Ahmed Helal
Did you ever find the solution to the problem? I do have the same problem..
Not yet... Unfortunatelly till now we need to flip 2D blocks manually, and no autodesk support or answer about that issue. I hope someone tell us that this annoying behavior is not present on 2014, or at least they are working on a workaround/fix.
Thanks for the quick answer!
Unfortunately I do use the 2014 version..
m_madrzak
in reply to: Erik_Halvarsson
try to change Small bore piping.. to the smallest dimension (check attachment) in Title blok and Display
small pipe sometimes makes some issue
Regards
Michał Mądrzak
Plant Specialist
m.madrzak@mat.net.pl
Phone +48 12 252-06-25
Mobile. 693-015-910
”Boost
