i want to migrate cats and specs from 2014 to 2015 with the P3D Spec Editor. After selecting Tools, Migrate Specs and Catalogs is choose the cats and specs to migrate. Spec Editor shows that migration is complete, the message also shows that migrated files can be opened in the migrated files folder C:\AutoCAD Plant 3D 2015 Content.
This folder is not created and chosen specs and cats are still dated old version.
Where can i find the migrated files folder?
thanks,
regards, Jan
Solved by jabowabo. Go to Solution.
If migration isn't required for 2015, how do I get the copied spec to point to a different catalog? I've copied a spec from the 2014 Content folder to the 2015 Content folder but it's still pointing to the 2014 version of the catalog. I'd like everything to be located in the same Content folder.
Try temporarily changing the path of the 2014 catalog and then opening the spec. This should force it to ask you for the new path.
