AutoCAD Plant 3D Forum
Welcome to Autodeskā€™s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Showing results forĀ
Did you mean:Ā
Method to get a cost estimate using BOM.
5 REPLIES 5
2222 Views, 5 Replies
Hi all,
I have a question about estimating the real life cost of construction of a Project designed in Autocad. (I use Autocad Plant 3D)
What I want to know is what method should I use. I searched the forums and didn't find a clear answer on what is the best method.
Here is what I think would work, but before actually making it, I want to know, from experienced users, what works and what doesn't.
Option 1- Assign a price tag to every piece of equipment / Produce a BOM / use a formula in the BOM to get the total price.
Option 2- Assign a price tag to every piece of equipment / Produce a BOM / Export to excel and create the formula to get the total price.
Option 3- Produce a BOM / Use Excel to assign a price to every piece of equipment using unique IDs in a price list and calculate the total price.
Which one is better ? Maybe the best option would be something else completely ?
There is not an easy answer I guess!
Thanks!
5 REPLIES 5
dgorsman
First, try the Plant 3D forum - they will have much better idea of estimating in your field than those here.
Second, try project management sites - this one is primarily for technical support, and most of the posters here are technically (rather than manager -ially) oriented.
Thanks to the admin for moving the post.
KenFauver
Hi Mad,
My option is a variation of your Option #1. I would add the price field to the catalog and Calculate the Total cost by generating a report in Report Writer. The report writer allows you to use expressions similar to excel.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist ā€“ Plant
Oil and Gas Solutions
I would say option 3 is your best bet.
Reason being is to tally up pipe lengths is easier done in Excel. (With pivot tables and such)
Also with a price change, it would mean re-doing your catalogues and specs, updating models, etc etc...
My opinion anyways...
Good luck!
Thanks for those who answered. Choice #3 seems to be the way to go since I have many pipes in my design. But this will have to wait...
Please keep the thread alive as I am experiencing a frustrating FATAL ERROR : Unhandled Access Violation Reading 0x0000 Exception at f50cd74eh... for whatever this means!
Will be back as soon as I get this fixed.
ā€Boost
