AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Measuring Plant 3D objects
9 REPLIES 9
Message 1 of 10
kudryavcevrm
3743 Views, 9 Replies
Hi, Autodesk experts and power users! How can I measure ("_DIST" command) plant 3D objects (e.g. supports)- they have not any snap points (EndPoints), except the only one in center. Our users strongly need such feature,may be they need additional snap points?
9 REPLIES 9
Message 2 of 10
Ahmed1081975
in reply to: kudryavcevrm
Hi Autodesk Supports,
In the same issue It' required to measuring between pipes and steel supports so how can I measuring pipe ( from face flange to face Example)
Ahmed Helal
Message 3 of 10
Currently you can only look for the support properties to look for the sizes of the support. See here the attached snapshot. In the preview you will see which property shortcut will be used for what.
If you want to add here an enhancement request, please, log it here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Regards
Bernd
Bernd G.
Senior Product Support Specialist
Message 4 of 10
Thank you very much, Bernd and thank you, Ahmed!
Of cause, I would like to add a product enhancement request, but unfortunately I can't to do this - there's no Plant 3D Item in products list at the web page Bernd has provided above
Message 5 of 10
I have created an enhancement request for you and also informed the web team to add Plant 3D to the product list for enhancement requests.
Regards
Bernd
Bernd G.
Message 6 of 10
I really appreciate your help,Bernd
Message 7 of 10
Ahmed1081975
Hi Bernd
Can you please do the same thing For me ?
Ahmed Helal
Message 8 of 10
Done 🙂
Bernd G.
Message 9 of 10
Thanks Very much Bernd
Message 10 of 10
Hi Autodesk Support Team,
I am using Plant 3D 2024, not sure if the enhancement requested above has been implemented!!!
Need the Object snaps to measure distances and/or drawing some construction lines etc.
Any help in this regard will be highly appreciated.
Samir.
”Boost
