Is there a way to map attributes from a drawing to Plant 3D attributes?
I receive a drawing template from our client with attributes in it. (the use it to read out the data in their system) I want to map my own data (drawing properties) to the one of the border. I know it is possible for ISO drawings. I can't get it to work with Ortho.
Solved by dave.wolfe. Go to Solution.
You have to use fields in ortho or PnID drawings. Take a look at the default PnID template.
Dave,
I know how to use the field option, but I want to link the attributes to plant 3D attributes.
The orthographics don't work like that. In the isometrics, when the drawing is created the program populates the title block. There is not matching functionality for orthos, so you have to use fields to link project or drawing properties to attributes.
