AutoCAD Plant 3D General DIscussion
Active Member
cpambo
Message 1 of 7 (435 Views)
Makeup Length for Cut Piece
435 Views, 6 Replies
09-19-2012 12:32 AM
I need to add a Makeup Length in the Cut Piece list if I put Field Fit Weld (FFW) on the pipe.  Attached is my setting for the Makeup Length.
The Makeup Length is added to the BOM but it does not show in the "Length" column of the Cut Piece list.  How do I set this up?
Thanks.
RodKreiss4326
Message 2 of 7 (274 Views)
Re: Makeup Length for Cut Piece
09-25-2013 10:13 AM in reply to: cpambo
I have this same problem.
Is there a resolustion?
Rod
RodKreiss4326
Message 3 of 7 (136 Views)
05-22-2014 11:24 AM in reply to: cpambo
Does anyone have any sugestinos on this one.
We manulay go back thur the Iso and and to the legths.
Is there a better way?
Employee
PeterQuinn
Message 4 of 7 (125 Views)
05-22-2014 04:23 PM in reply to: RodKreiss4326
Does the setting that the first post sets in the UI work?
Or, does it work when you edit ISOCONFIG.XML? (search for Makeuplength)
Or are you seeing the iso ignoring this setting?
Peter Quinn
Senior Product Manager
Autodesk, Inc.
RodKreiss4326
Message 5 of 7 (101 Views)
05-27-2014 07:36 AM in reply to: PeterQuinn
Peter,
The setting in the UI and in the .xml file works, it adds length to the overal length of pipe in the BOM.
But it does not adjust the length of the cut list.
Rod.
Employee
PeterQuinn
Message 6 of 7 (96 Views)
05-27-2014 11:50 AM in reply to: RodKreiss4326
How does the extra length get allocated? Is it all on one side or another? Or, does the pipe on each side of the field weld get half of the extra length?
Peter Quinn
Autodesk, Inc.
RodKreiss4326
Message 7 of 7 (92 Views)
05-27-2014 03:20 PM in reply to: PeterQuinn
The majority of the time it would be next to a fitting.  But in the pipe to pipe scenario, the extra lenght would be place on the piece that is not full lenght (42' or 21')(DRL or SRL).
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
