AutoCAD Plant 3D Forum
Makeup Length for Cut Piece
7 REPLIES 7
Message 1 of 8
cpambo
1406 Views, 7 Replies
I need to add a Makeup Length in the Cut Piece list if I put Field Fit Weld (FFW) on the pipe.  Attached is my setting for the Makeup Length.
The Makeup Length is added to the BOM but it does not show in the "Length" column of the Cut Piece list.  How do I set this up?
Thanks.
7 REPLIES 7
Message 2 of 8
rkreiss375
in reply to: cpambo
I have this same problem.
Is there a resolustion?
Rod
Message 3 of 8
rkreiss375
in reply to: cpambo
Does anyone have any sugestinos on this one.
We manulay go back thur the Iso and and to the legths.
Is there a better way?
Message 4 of 8
PeterQuinn
in reply to: rkreiss375
Does the setting that the first post sets in the UI work?
Or, does it work when you edit ISOCONFIG.XML? (search for Makeuplength)
Or are you seeing the iso ignoring this setting?
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Message 5 of 8
rkreiss375
in reply to: PeterQuinn
Peter,
The setting in the UI and in the .xml file works, it adds length to the overal length of pipe in the BOM.
But it does not adjust the length of the cut list.
Rod.
Message 6 of 8
PeterQuinn
How does the extra length get allocated? Is it all on one side or another? Or, does the pipe on each side of the field weld get half of the extra length?
Peter Quinn
Autodesk, Inc.
Message 7 of 8
rkreiss375
The majority of the time it would be next to a fitting.  But in the pipe to pipe scenario, the extra lenght would be place on the piece that is not full lenght (42' or 21')(DRL or SRL).
Message 8 of 8
cherycntt2101
in reply to: cpambo
I am also missing that but not where to buy
”Boost
