AutoCAD Plant 3D General DIscussion
Valued Mentor
18 Kudos
Post 1 of 6
Made the mistake of downgrading from windows 7 to windows 8....
904 Views, 5 Replies
11-01-2012 02:12 PM
everytime I try to use Quickproperties
I get an error
"Microsoft .NET Framework
Unhandled exception has occured in a component in your application.
If you click Continue, the application will ignore this error and attempt to continue.
Object reference not set to an instance of an object."
I am just trying to get everything reset since Windows 8 completely messed up everything and I had to reinstall autocad ( yet again - and re-authorize ) wiped everything off the computer since I had to "freshen" up windows 8 ( try to avoid this at all costs ) and basically waste a day...*sigh*
Now I am getting lots of little errors..
Oh if you use windows gadgets ( which I do on a daily basis ) I would avoid Windows 8.. hell if you work or play I'd avoid windows 8...
just avoid it.  Microsoft continues their tradition of a good OS followed by a complete waste of time OS ( windows 8 )
but back to the original problem - QP does not work anymore for me, and apparently .NET is upto date.
any suggestions... ( I am going to attempt to try windows 8 )
DETAILS of error message follows
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Customization.quickPropertyControl.set_IsRolloverToolTip(Boolean value)
at Autodesk.AutoCAD.Customization.quickPropertyControl.populateFromAllCuiFiles(Boolean bRolloverTooltips)
at Autodesk.AutoCAD.Customization.MainForm.FindAndSelectTreeNodeRecursive(CUITreeNode treeNode)
at Autodesk.AutoCAD.Customization.MainForm.SelectQPNodeForTheObjectType()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 19.0.0.0
Win32 Version: 19.0.55.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcdbMgd.DLL
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 3.5.19.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AdApplicationFrame.DLL
AdWindows
Assembly Version: 3.5.21.0
Win32 Version: 3.5.21.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AdWindows.DLL
PresentationFramework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/Acmgd.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcWindows.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
WindowsFormsIntegration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcWindows.resources.DLL
PresentationUI
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcFusion
Assembly Version: 1.0.4413.25343
Win32 Version: 0.2.0.230
CodeBase: file:///c:/program%20files/autodesk/applicationplugins/fusionplugin2013.bundle/contents/win64/acfusion.arx
AcFusionRes
Assembly Version: 0.2.0.230
CodeBase: file:///C:/Program%20Files/Autodesk/ApplicationPlugins/FusionPlugin2013.bundle/Contents/Win64/AcFusionRes.dll
PnPDataLinks
Win32 Version: 4.0.26.00
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDataLinks.DLL
PnPCommonArx
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/pnpcommonarx.arx
PnPProjectManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPProjectManager.arx
PnPProjectManagerMgd
Assembly Version: 4.0.26.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPProjectManagerMgd.DLL
PnPCommonMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCommonMgd.DLL
PnIDMgdInternal
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDMgdInternal.DLL
PnIDUIMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDUIMgd.DLL
PnPCIP
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCIP.DLL
PnIDCIP
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDCIP.DLL
PnP3dContentMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dContentMgd.DLL
PnPUtilMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPUtilMgd.DLL
PnP3dMain
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dMain.DLL
PnP3dSpecUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dSpecUI.DLL
PnP3dSpecUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dSpecUI.resources.DLL
PnPProjectManagerUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPProjectManagerUI.DLL
PnPProjectManagerUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnPProjectManagerUI.resources.DLL
PnPRevisionCloud
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPRevisionCloud.DLL
XDbReferenceManagerArx
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/XDbReferenceManagerArx.DLL
XDbReferenceManagerArx.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/XDbReferenceManagerArx.resources.DLL
PnIDMain
CodeBase: file:///c:/program%20files/autodesk/autocad%20plant%203d%202013%20-%20english/pnidmain.arx
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcWindows.dll
PnP3dWorkspace
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dWorkspace.DLL
PnP3dWorkspace.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dWorkspace.resources.DLL
PnP3dCustomControlLibrary
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dCustomControlLibrary.DLL
PnP3dOrthoDrawingsUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dOrthoDrawingsUI.DLL
PnPDwg2dUtil
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDwg2dUtil.DLL
PnPDwg2dAnno
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDwg2dAnno.DLL
PnPDwg2dDbx
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDwg2dDbx.DLL
PnP3dOrthoDrawingsUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dOrthoDrawingsUI.resources.DLL
PnPDwg2dDef
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDwg2dDef.DLL
PnP3dIsoUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dIsoUI.DLL
AliasRibbonUI
Assembly Version: 19.0.55.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AliasRibbonUI.DLL
AliasUnderlayRibbonUI
Assembly Version: 1.0.4427.22204
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AliasUnderlayRibbonUI.DLL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
ManagedMC3
Assembly Version: 6.4.0.0
Win32 Version: 6.4.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/ManagedMC3.DLL
PresentationFramework-SystemCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
UIAutomationTypes
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
PnPDataObjects
Assembly Version: 1.0.4436.40546
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDataObjects.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Autodesk.AutoCAD.Interop
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/Autodesk.AutoCAD.Interop.DLL
Autodesk.AutoCAD.Interop.Common
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/Autodesk.AutoCAD.Interop.Common.DLL
PnP3dProjectPartsMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dProjectPartsMgd.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
PnIDProjectPartsMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDProjectPartsMgd.DLL
PnP3dConnectionManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dConnectionManager.DLL
PnP3dPartsRepository
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dPartsRepository.DLL
PnP3dDataLinkManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dDataLinkManager.DLL
PnP3dOrthoProjectPart
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dOrthoProjectPart.DLL
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
PnPSQLiteEngine
Assembly Version: 1.0.4436.40554
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPSQLiteEngine.DLL
System.Data.SQLite
Assembly Version: 1.0.65.0
Win32 Version: 1.0.65.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/System.Data.SQLite.DLL
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Microsoft.VisualC
Assembly Version: 10.0.0.0
Win32 Version: 11.00.50709.17929 built by: FX45RTMREL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualC/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
PnIDProjectParts
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDProjectParts.Arx
PnIdGuiUtils
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIdGuiUtils.DLL
PnIDGUIUtilMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDGUIUtilMgd.DLL
PnP3dProjectParts
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dProjectParts.arx
PnP3dPipeRoutingUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dPipeRoutingUI.DLL
PnP3dPipeRoutingUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dPipeRoutingUI.resources.DLL
PnP3dSpecManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dSpecManager.DLL
PnPCommonUIMgdCs
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCommonUIMgdCs.DLL
PnP3dPlantContentUpgrade
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dPlantContentUpgrade.DLL
PnP3dProjectManagerUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dProjectManagerUI.DLL
PnPIsoCore
Assembly Version: 2.0.24.0
Win32 Version: 2.0.24.00
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPIsoCore.DLL
PnP3dProjectManagerUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dProjectManagerUI.resources.DLL
PnPCommonUIMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCommonUIMgd.DLL
PresentationFramework-SystemData
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
PnPWelcomeManager
CodeBase: file:///c:/program%20files/autodesk/autocad%20plant%203d%202013%20-%20english/pnpwelcomemanager.arx
AcLivePreviewContext
PnP3dObjects
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dObjects.dbx
PnP3dPipeUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dPipeUI.DLL
PnPValidation
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPValidation.DLL
PnIDDwgValidation
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDDwgValidation.DLL
PnIDDwgValidation.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnIDDwgValidation.resources.DLL
PnIDWorkspace
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDWorkspace.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcLayer.resources.DLL
PresentationFramework.Luna
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcMrUI.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcMrUi.resources.DLL
AcMr
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcMr.DLL
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
UIAutomationProvider
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
PnPDataGrid
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDataGrid.DLL
PnPDataGrid.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnPDataGrid.resources.DLL
PnP3dObjectsMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dObjectsMgd.DLL
PnP3dACPUtils
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dACPUtils.DLL
AcCustomize
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcCustomize.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcCustomize.resources.DLL
System.Design
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
AcCommandToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcCommandToolTips.DLL
AcCommandToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcCommandToolTips.resources.DLL
AcDialogToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcDialogToolTips.DLL
AcDialogToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcDialogToolTips.resources.DLL
PnP3dEquipmentUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dEquipmentUI.DLL
PnP3dCommonUIMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dCommonUIMgd.DLL
PnPCommonDbxMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCommonDbxMgd.DLL
PnP3dEquipmentUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dEquipmentUI.resources.DLL
PnP3dUIUtilsMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dUIUtilsMgd.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Firstly.......check if the AutoCAD versions are supported on Windows 8.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Answer....not yet.
Valued Mentor
65 Kudos
Post 2 of 6
Re: Made the mistake of downgrading from windows 7 to windows 8....
11-01-2012 04:52 PM in reply to: JohnHolder
i was wondering if someone was going to have a crack at the win8 'downgrade' (lol)
the word I hear is DONT BOTHER unless you have a tablet
Its microsofts first attempt at a full blown app driven touchscreen style OS so ill probably be sticking with win7 for the next couple of windows releases
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Employee
7 Kudos
Post 3 of 6
11-01-2012 06:13 PM in reply to: JohnHolder
Answer....not yet.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Valued Mentor
18 Kudos
Post 4 of 6
11-02-2012 08:54 AM in reply to: JarrodMudford
Besides the normal slew of errors Autocad has that pop up constaintly...
Windows 8 still sucks and and is a bad idea IMO for anyone who works with a computer to use.
Expecially with duel monitor... that is where Windows 8 really sucks.
Master Yoda.
504 Kudos
Post 5 of 6
11-05-2012 08:07 AM in reply to: JohnHolder
And this is based on... what?  Running software which isn't compatible?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Mentor
18 Kudos
Post 6 of 6
11-05-2012 12:55 PM in reply to: JohnHolder
Considering it crashes on software it is compatible with. It ran fairly well.
Yes I realize I jumped the gun a little quick. After using it for a few days on my laptop with no issues.
Master Yoda.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
