AutoCAD Plant 3D Forum
Lost Connection infor in Plant 3D 2012 ISOs
2 REPLIES 2
314 Views, 2 Replies
Hi all
I met a very strange problem:
In the attached dwg file,there are 2 simple pipeline with linenumber 0001 and 0002
0002 connect on 0001 using tapping connection.
when generate iso,we can see:
1.if generate quick iso for both of the two pipe at the same time,we can see that in the ISO of 0001,there is connection infor while there is not in 0002(open end)
2.if generate quick iso for 0002 singly,we can see the connection infor in the iso
3.if generate product iso for both of the two pipe at the same time, we can see that  in the ISO of 0001,there is connection infor while there is not in 0002(open end)
4.if generate product iso for 0002 singly,we can't  see the connection infor in the iso(open end)
so what cause it happen?
is it a bug in 2012?
Hope for your reply soon.
thanks and regards.
Rong
2 REPLIES 2
Vicky.Wu
in reply to: 19820415
Dear Rong,
It was a limitation in Plant 3D 2012. We will investigate it. Thanks for your report.
Vicky
Autodesk Plant Solutions
in reply to: Vicky.Wu
So in the current version ,if we have some solution?
It's very important for us.
thanks
”Boost
