AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Locating moved Ortho drawings
1 REPLY 1
JoeKay
245 Views, 1 Reply
Due to a file structure change, had to change where our Ortho drawings output location was.
The problem is you can NOT 'locate' the drawings after they have been moved by right clicking and selecting 'locate drawing' through the project manager. You can do this for the 3d models and p&ids but not the Ortho drawings, unless I am missing something.
Seems odd that the Ortho drawings are designed to be your normal sheet files but then you can't ever move them. Things change over the course of a project and sometimes drawings move. I'm hoping someone can enlighten me on how to move and 'locate' them or the reason behind not being able to move them.
Thanks.
1 REPLY 1
vakhtang
in reply to: JoeKay
i assume the only way here is to remove drawing from project and then copy it back to project from new location. it IS really wrong btw, totally agree
”Boost
