hello all
just i cannot find any way to make the project name or number is automatic shown as part of file name. in my company we always use the project number as part of file name
i find this topic on this forum but till now it is not solved
http://forums.autodesk.com/t5/autocad-plant-3d-general/p3d-2012-file-name-format/m-p/3605650#M6850
Solved by Dan.Scales. Go to Solution.
It is not possible to automatically acquire the project name or number so that it is included in the file name.
An alternative option would be to add a new selection list to the project and add the project number as a new row. This would require the number to be selected from a drop down list but it would be more locked down than simply typing in the name.
Dan
If you create the selection list under Engineering Items you will be able to use it in the file name:
Hope this helps.
Dan
