I have problems with iso annotation. I would like to have in my iso drawing same line number as in 3D.
For example I have line number assigned in 3D (left side in photo), but if I have default settings in iso xml file (right side in photo) there is no possible to use this value in iso.
Can I configure this, that I will have this line number shown also in iso piplines?
It looks like you have already to modify the isoconfig.xml.Iis that correct?
Without knowing what is being outputted on the iso, I can really only help you fix the .xml and give another way of creating it.
To fix the .xml:
I believe the "PIPELINE-REFERENCE" should be the same as the line number field you have in the model. You can check this by looking at the .PCF file created with the iso.
If that is all you need for the iso, then:
That should output whatever you have for "PIPELINE-REFERENCE"
If needed you can add attributes from the iso.atr file to the "LineFields". Then just modify the "LineFormat" to something line this "{0} {1} {2}".
Of course you will need to add the attributes to the iso.atr file too.
Hope this helps...
And was clear...
I am just wondering if there is a possibility that I can put this Line Number Tag (ex. AP-0029-DN150-SS) from Plant put directly to iso drawing. Or I need to change xml and put there 4 new items instead of default "Size PIPING-SPEC"
