The below help document should help you understand the difference,
Vinod,
Can you help me with line tags. I have set mine up similar to what your link shows. I have made a new tag like that one in the P&ID area (Project Setup -> P&ID Class Definitions -> Engineering Items -> Lines-> Pipe Line Segments). The P&ID's work great and the tags work. However, when I add the tag to (P&ID Class Definitions -> Pipe Line Group) as well as to. (Plant 3D Class Definitions -> P3d Line group) I get the error in my model that the line numbers don't show up because the P&ID tag doesn't match the 3D Tag.
The only way I have found to fix this is to revert them back to being just line numer and not the full tag I need. I would really like to be able to use my full tag nuimber in the drop down where I route pipe in the model.
I have attached some screen shots, Any help anyone can provide would be greatly appreciated.
Ed
P.S. sorry to hijack this thread, 🙂
Your definition in PIpeline segments is wrong to me....it should be as "target object",
then dont forget to verify you mapping....
i have attached some screen shots mine works well iether when you start a project from P&id or if you want to draw directly on 3d without using the p&id
Regards
Indesh
