AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Line number stuck
14 REPLIES 14
Message 1 of 15
Gabriel.N
5269 Views, 14 Replies
Line number stuck
After a FATAL ERROR, (I didn't recoverd) I can not associate two Line Numbers, that were being drawn during the Fatal Error. I tried several ways but the information don't get in. The layer stays on "0" and in the proprites stays "?-?-?-?", I tried to purge, remove the drawing from the project and copy into the project again, compress and purge data base, nothing works.
    Hey, it's time to redo the Plant 3D, the AutoCAD while a solution to it is also its greatest limitation.
    Please, no excuses.
Att.
Gabriel Nogueira.
14 REPLIES 14
Message 2 of 15
in reply to: Gabriel.N
Have you already tried the PLANTAUDIT command? Run this command when nobody has the project open
Message 3 of 15
hendriksegveld
and use the PnPLocalDataCachePurger.exe
Message 4 of 15
Gabriel.N
in reply to: hendriksegveld
Unfortunately it did not work. Any other ideias?
Message 5 of 15
Please attach it... if it is possible...
Message 6 of 15
EricNyh
I have had this happen to me.  It is very frustrating.  I was forced to change the line number by appending an "A" to the end.  For example, my line number was CW-1234, I changed it to CW-1234A.  When I created iso's, I then removed the "A".  It is not the best solution, but kept things moving along.
One thing that a Plant support person told me to do was to create a NEW project based on the troubled one and add the existing drawings to the new project.  This resets the database and allows you to assign the old line numbers again.  This is not a good solution as well.
Eric
Message 7 of 15
hendriksegveld
in reply to: EricNyh
What I would do:
1 rename line number (add A)
2 Purge the drawing
3 Command: Auditproject
4 PnPLocalDatacachePurge.exe
5 rename line number to origin (-A)
If still not working:
4 create new drawing in project
Did you try to open de recovered drawing already (and rename)
I think the problem is the databasemanager, it holds info about the original line number.
Succes
Message 8 of 15
Where can one get PnPLocalDatacachePurge.exe??  And can anyone provide more info on what this does?  I've searched Adesk forums and did a google search and can't find any info on this.
Can anyone give more guidance on this?
THANKS!
Message 9 of 15
"C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - English\PnPLocalDataCachePurger.exe"
With kind regard,
Henk Segveld
Job opportunities at www.werkenbijzeton.nl
[cid:image4b8b54.PNG@a8c1c157.41b26702]
Zeton BV
PO Box 9 - 7500 AA ENSCHEDE - The Netherlands
Marssteden 206 - 7547 TD ENSCHEDE
Phone +31 53 428 41 00 / Fax +31 53 428 41 99
Web: www.zeton.com
Trade register Twente Salland 06054827
________________________________
DISCLAIMER:
The information in this e-mail is confidential and intended solely for the person to whom it is addressed. If this message is not addressed to you, please be aware that you have no authorisation to read the rest of this e-mail, to copy it or to furnish it to any person other than the addressee. Should you have received this e-mail by mistake, please bring this to the attention of the sender, after which you are kindly requested to destroy the original message.
Message 10 of 15
you should also regularly delete the content of the temp folder: C:\......\AppData\Local\Temp
Message 11 of 15
Smiley Happy when you are cleaning-up your system, delete at last the content off:
C:\Users\XXX\AppData\Local\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\GraphicsCache
Message 12 of 15
delete content:
C:\Users\xxx\AppData\Local\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\GraphicsCache
Message 13 of 15
eadkins73
I have also found the only way to "purge" the line number with an error is by creating a new project and copying the drawings to it.
I would guess that there is something in the database that is messed up.  If you could find it in the SQL database I would guess that you could fix it.  I don't know how you would do that though.  Maybe the support guys can help.  Really the whole line numbering and taging should be revisited as well since I have had line numbering/tagging issues a lot lately.
Ed Adkins
EA2 Engineering
www.ea2eng.com
Message 14 of 15
teoelt
Hi , guy. Try command "compressproject".
尝试压缩一下数据库
Message 15 of 15
Bob_Lipchik
in reply to: teoelt
Thanks teoelt!  COMPRESSPROJECT worked perfectly!!
”Boost
