Hi, I'm trying to set up the format for the line number. I've already done it in the TagFormatName but when I generate the isometric it keeps on putting extra fields. Example: my TagFormatName is <Size>-<Service>-<Spec>-<Number> but the isometric callout has added "-<Size>-<Spec>" after my TagFormatName. How can I take it off?
Thanks in advance!
cpambo
Solved by Rich.O.3d. Go to Solution.
you want to look at the tag annotations (to the right of where you set the tag format under the 'P3d Line Group' node...go to the 'Pipe Run Component' node)
I think that you may be using this one...Line Number Callout [Line Number Tag]
try this one...Full Line Number Callout [Size-Line Number Tag-Spec]
Hello Richos,
Is this applicable on isometric drawings generated.
I think this is the tag for generated ortho drawings.
I think this is the suitable soulution by jason drew
i can't find that options in my Project Setup.
Please, can you post a screenshot of your Project Setup??
Thanks!
