AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
line no tag problem
3 REPLIES 3
NRKee
715 Views, 3 Replies
line no tag problem
Can any one help out I can not get the line no to come out right. (see attached) it tends to add an additional line size,spec to it
thanks
Jo
3 REPLIES 3
Attila.Vallyon
in reply to: NRKee
Open the isoconfig.xml in your project folder and look for this:
 <LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Enabled="true" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
and change the red values.
Attila Vallyon
NRKee
in reply to: Attila.Vallyon
Thanks Attila
paragnewe
Hello Attila,
I am also facing same error and tried to edit isoconfig.xml as per your suggestion.
but when I editing contents from highlighted area, ISO will extract without tag.
i tried to add only "SIZE" but still it is not comming.
please help me in this..
-Regards
Prag
”Boost
