Can any one help out I can not get the line no to come out right. (see attached) it tends to add an additional line size,spec to it
thanks
Jo
Solved by Attila.Vallyon. Go to Solution.
Open the isoconfig.xml in your project folder and look for this:
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Enabled="true" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
and change the red values.
@attila_vallyon wrote:Open the isoconfig.xml in your project folder and look for this:
Hello Attila,
I am also facing same error and tried to edit isoconfig.xml as per your suggestion.
but when I editing contents from highlighted area, ISO will extract without tag.
i tried to add only "SIZE" but still it is not comming.
please help me in this..
