I have one project where there are this problem: if it's created new line with new tag it's assign ok, then it's created another pipe with new tag. After this the tag of the first pipe is changed in properties to the tag of the second, and in this moment the TAG it's not assign... The name it's convert to "unnasigned" and seems like the pipe is detach from PipeLine Group.
It's happen only in one project, in the default configuration is posible to change the TAG of pipes without problems, but in this case not. Which is the problem? I revise all configuration of this project with the default and all options are set the same...
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
