Hi to everyOne,
I have a problem displaying Lap Joint Flanges with Stub End in Isometrics Drawing.
I Try a lot of combinations modifying Isometric Symbol for Lap Joint and everytime same problem
One of them go to the right place and the other not.
So I don´t Know where come from the problem if is from Flange Acad Block or Stub End Acad Block.
In the next image you can see the result. Please I need a lil' help how did you configurate yor AcadBlocks (Ports, CP, Flip and every needed)
Thanks.
Flange Lap Joint SKEY: "FLLB" - Block: "FittingFlange"
Stub End SKEY: "FLSE" - Block "Stub-End"
And if you set up only one symbol?
Instead of having two separate symbols, make only one, for example for the lap joint only. And remove the iso symbol skey from the stub end part.
So it will work as a single flange symbol and always will be positioned properly
Thanks for you replay, and yes that was I finally did, so and so.
I mind, I generated a 3D Acadblock whith flange and collar in one.(With that you can make back to back welding collars)
Next plantpartconvert, and insert into my catalog and Spec.
I make a Skey associate with a New AcadBlock for Isometric. (That idea come from this post: "Back To Back Lap Joint")
Now work pretty well.
Thanks and hope can help anyone.
Graphics Step by Step.
