Is there language packs as there is on the standard version of AutoCAD?
If not, why ? because it is multilingual as AutoCAD and AutoCAD Structural Detailing that they have language packs.
Sorry for my poor English and thank you for your answers.
Instead of having an add-on language pack, Plant 3D/P&ID has separate versions for local languges. You should be able to get French, German, Japanese, Russian, and Chinese versions.
You will say for the change from english to german I have every time to uninstall english and then install german?
Because both eng and ger on one PC is not working!
Please Autodesk make Language Packs for Plant and P&ID 2014!
Best regards
Adrian Grischott
Do you really need language packs, or do you just need to have English and German installed side by side? What I mean, do you care how it's done?
If you have only one machine, one installation per language why not (although as said gri4775 currently no possibility of 2 installation on one PC).
But if you have a park with fifty PCs on which you must install three languages it starts to become more difficult for the setting and maintenance of installations.
And finally why make language pack for AutoCAD, Structural Detailing, Revit, etc. and not for Plant 3D?
Sincerely,
