i am wondering if there is a knife gate valve in the catalog or something similar enough for me to only have to size the end to end dimensions? also..why would there be a symbol for a knife gate valve for pnid's in the autoplant 3d suite, but not a knife gate valve in the valves catalog? thank you in advance for your help.
Autodesk does not guarantee the completeness of Plant 3D catalogs.
Since there are a variety of manufacturers Valves, Autodesk can not take all types of valves.
r.
Hartmut
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
There are Knife Gate Valves (ANSI/ASME) in the software. Look under wafer valves they're there.
They exist in the ASME Valves Catalog.
I can locate ASME Valves Catalog but I can't find the knife gate valve is because it's got a defferent discripton ?
butterfly valve is nearest valve... but as per our work flow... I do valves via client and vendor catalogs.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
