AutoCAD Plant 3D Forum
Keep construction lines after using PLANTCONVERTLINETOPIPE
6 REPLIES 6
PatrickByrne
732 Views, 6 Replies
When using the "line to pipe" command (PLANTCONVERTLINETOPIPE), I select the construction lines for the pipe to draw, after putting in the pipe it deletes the construction lines. Is there a setting so that these lines are not deleted.
6 REPLIES 6
in reply to: PatrickByrne
Pick option erase after starting the Line to Pipe command, then select no.
Richard Strikker
CADTEAM.NL
PatrickByrne
Thank you, do you know if there is a setting for that so that the line is never erased?
lanl
Hi PatrickByrne,
Currently, there is no such system variable to control the lines never be erased.
Thanks.
Lei Lan
PatrickByrne
in reply to: lanl
Any chance you could be added to the wish list.
The way I accomplish converting line to pipe and keeping construction lines is to draw all construction lines on a dedicated layer (ex. Pipe Construction). I then freeze the "pipe construction layer before starting the line to pipe command. I then just thaw the pipe construction layer. It sounds complicated but I have toolbar button programed with a macro to do everything in one click. I will paste my macro below for reference. Just create a new custom command and program to button.
<^C^C-layer;s;0;lo;pipe_construction;;select \plantconvertlinetopipe -layer;u;pipe_construction;s;pipe_construction;; >
Chad
tfs-us
It seems like every piping software handles slope in incredibly horrible ways. So, many years ago I just started drawing all my sloped lines with a 3DPolyline lisp routine. Because of my work flow and this default nature, I've found the auto-delete on the LineToPipe command to be very annoying.
So, this is how I run the command now:
(defun C:CDD () ;C.onvert, but D.on't D.elete
  (command "PLANTCONVERTLINETOPIPE" "E" "NO")
  (princ)
”Boost
