I need to add an Item Stock Code field to the Piping Component Properties under the Size tab in the Catalog. This Item Stock Code will need to show up in the BOM on the Isometric.
Any help will be appreciated
Are you guys using the Item Code field? If you export your catalogs to Excel, you'll be able to populate the item code for each part size which will affect the spec, and be available in the iso.
