I am attempting to creat a custom fittings catalog for rubber/plastic lined pipe and I'm running into some issues. Let me explain my work flow (note: all of this is done on my C drive, no network stuff here), I model the fitting and save it as a 3d block, creat a new plant project, creat a new drawing file within the project, insert 3d block/save and run plant part convert/pick ports/save, relocate the converted block and all associated files ( it makes three dwg, XML and PNG file) to a combined fitting blocks folder on my desktop to keep them organized, go into spec editor and creat a new empty catalog, creat a new empty folder in the same folder as the catalog with the same name, creat components pick block from folder on desktop and everything goes fine.
Once I get everything into the catalog and into a spec and saved in my project I am unable to insert them into my piping model. The thumbnail in the fittings tool palette is just a white square however I see all of the information, ie long descriptions, for the fittings I just get a "can't find symbol for specified part" Message when I attempt to bring anything into the model. I was done some research and I'm pretty sure I'm doing everything correctly, so why isn't it working? Am I missing something?
Solved by patpat79. Go to Solution.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Best Regards,
Pat Andres
GHD Manila
I believe I found the issue. I was making my parts for different sized pipe in separate drawings, not in the same drawing. Thanks for the responses though!
Best Regards,
Pat Andres
GHD Manila
