So I've created some custom pipe specs in Spec Editor (2014) and have been trying to access them in Plant 3D (2014). I copied the specs to the project folder and when I use the dropdown menu from the Part Instertion tab to select the spec I get a warning box that says "Spec XXXX requires migration before it can be used". I go into Spec Editor and use the Migrate Specs and Catalogs tool and it says that the spec has been migrated successfully, but the message still comes up when I try to access the spec. I've migrated both the original file and the copied file, neither seems to fix the issue.
Solved by twdtech. Go to Solution.
From spec editor, open your custom spec from the project folder location and save the spec. You should now be able to use the spec in your project.
