AutoCAD Plant 3D General DIscussion
Distinguished Contributor
philip
Message 1 of 10 (349 Views)
ISSUE WITH 45 TEE's
349 Views, 9 Replies
06-18-2012 02:11 PM
Started a project in 2012 and had things working okay had run some isos off and all was good (image "45-2012")
Then migrated to 2013 and added a whole lot of new pipes reran some iso which have changed and now am finding that 45 tee's are not working anymore(image "45-2013")
Have started a new project and created a "custom part" and found that the issue is there still (thought it might be some of our custom Isometric symbols).
is this a bug with 2013??
Product Support
Venkatesan.A
Message 2 of 10 (323 Views)
Re: ISSUE WITH 45 TEE's
06-19-2012 12:06 AM in reply to: philip
Philip,
Thanks for highlighting.
A change request has been opened relating to this issue.
Venkatesan.A
Support Specialist
Product Support
philip
Message 3 of 10 (296 Views)
06-19-2012 01:09 PM in reply to: Venkatesan.A
any idea if this may come out as a fix this year or will it be in the next release of Plant (2014)?
Just so i know either to use or not to use 45 tees in upcoming projects.
Product Support
Venkatesan.A
Message 4 of 10 (255 Views)
06-25-2012 06:56 PM in reply to: philip
Sorry for the late reply, I am in discussion about this issue, please give me some time.
I will update you asap.
Venkatesan.A
Support Specialist
Product Support
philip
Message 5 of 10 (249 Views)
06-25-2012 07:46 PM in reply to: Venkatesan.A
thanks.
pata825
Message 6 of 10 (229 Views)
06-28-2012 01:46 PM in reply to: philip
Have we heard anything on this yet? I am having similar issues with lateral. Anyone found a good workaround? was thinking about grabbing the block from 2012.
philip
Message 7 of 10 (227 Views)
06-28-2012 01:48 PM in reply to: pata825
nothing as yet, I ended up doing a lot of manual works to get it looking half right so we could get job out.
pata825
Message 8 of 10 (224 Views)
06-28-2012 02:15 PM in reply to: philip
Manual work to your isos, or were you able to figure out a workaround to get the isos to come out right?
philip
Message 9 of 10 (221 Views)
06-28-2012 02:19 PM in reply to: pata825
I changed the isos after they were made by Plant.
Only workaround i can think of is to create a user SKEY, i have not tried this yet.
Product Support
Venkatesan.A
Message 10 of 10 (153 Views)
09-04-2012 08:04 PM in reply to: pata825
A Hotfix has been issued that address this issue. The link is as below.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20164796&linkID=14116968
Let me know if this works fine for you.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
