Started a project in 2012 and had things working okay had run some isos off and all was good (image "45-2012")
Then migrated to 2013 and added a whole lot of new pipes reran some iso which have changed and now am finding that 45 tee's are not working anymore(image "45-2013")
Have started a new project and created a "custom part" and found that the issue is there still (thought it might be some of our custom Isometric symbols).
is this a bug with 2013??
Philip,
Thanks for highlighting.
A change request has been opened relating to this issue.
any idea if this may come out as a fix this year or will it be in the next release of Plant (2014)?
Just so i know either to use or not to use 45 tees in upcoming projects.
Sorry for the late reply, I am in discussion about this issue, please give me some time.
I will update you asap.
Have we heard anything on this yet? I am having similar issues with lateral. Anyone found a good workaround? was thinking about grabbing the block from 2012.
nothing as yet, I ended up doing a lot of manual works to get it looking half right so we could get job out.
I changed the isos after they were made by Plant.
Only workaround i can think of is to create a user SKEY, i have not tried this yet.
A Hotfix has been issued that address this issue. The link is as below.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20164796&linkID=14116968
Let me know if this works fine for you.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
