In the ISOS it is always displayed the 'MATL' and the name of the spec to which the component belongs (see image). In cases using different specs in the same line, the drawings end up too loaded with this information. Is there a setting for not having to remove this text / information manually ?
Yes, all the settings have changed in 2012 since Plant 3D doesn't use Isogen anymore. Right now on the default setup, it just calls out the spec. I don't know if there is a way to add a material callout description or not.
is there a way, in 2014 and 2015 versions, to remove from the settings of isometrics generation the spec change text displayed ?. see img
thanks
