I'm having issues with the Isometrics. The 'De-Mystifying' instruction weren't any help either. I'm trying to get as much info and lines on one Iso sheet.
For Example I have a main High Pressure gas line with a 2in by pass. Both have separate line numbers. I need both of these lines to show up on one Iso sheet. Now I know I wont get everything on 1 sheet but at least need the by passes (with different line numbers) to be on one ISO sheet together.
Any insight to this would be greatly appreciated. Thanks.
You cannot do this with Production Iso. Quick Iso will allow you to combine multiple line numbers into one sheet.
The check mark is not the root of the issue. By design the software will not drop multiple line numbers on one production iso. The only workaround is a quick iso. Unfortunately, it is true you lose all line group tagging and attributes dependent on line group properties.
Historically isometric generation has been focused on spool (or spool-like) drawings where you have one and only one line number per drawing. There hasn't been much development in system-type isometrics which allow for multiple connected lines, or single or multiple disconnected lines. Could be a legacy of the PCF format.
I think there are some very good opportunities for work in these areas.
Just on a side note, why does the bypass have a different line number? Is it a different Spec?
Interesting... thanks 🙂
The volume of checking and editing doesn't change that much. There's just more on each drawing to go through, so each drawing takes longer. There's some give and take between the two, but there is some speed benefits to having more drawings with less on them - checking and modification is faster, avoiding bottlenecks and allowing more people to be thrown at the work. Its a matter of finding the optimum point between each.
We have some clients which prefer system style isometric and regardless of what program is used generating those isometrics are a PITA. And I've also worked on projects with bypasses that are separate line numbers, which are also difficult. So you're not alone. 🙂
I have an oddball idea. If you're looking to reduce the number of sheets, could you strip off the titleblock and put multiple pipeline graphics on one sheet using paperspace?
Is there any solution for this question, because i needed to get an overview with multiple line number in one iso
There has been no change in the program regarding this issue. Production isos will only include a single line group on an iso. This is very unlikely to change due to the way sheet attributes are populated.
