I encountered a problem when generating isometrics:
Several components with same type and different size are merged into one row in BOM, and are gived the same item number, Quatity is the sum of all.
Above I use "Long description (Family)" for the <description> field in the table. After I Change it to "Long description (Size)" , then it becames:
This time the PIPES are correct, but FITTINGS/FLANGES/VALVES are still not.
I Found that this happens only when I use specs built by myself(Such as Spec base on GB Catalogue), When I model the same pipes with Specs come with the software, it will be allright. Below is the BOM appears modeling by Spec CS150:
Then it's no problem.
Any one know why? This problem is annoying me and my colleagues very much. So many Isometric drawings must be amended by hand!
P3D 2012 and P3D 2013 have the same problem.
PS: Searching the forum found that others have the same problem, but there's no resolution untill now.
PCFs:
This seems to be strange.Seems working ok with my Plant3d 2013.
Could you post your specs so that I can use it.
You might have specified the Item code for the above items same in you custom spec, that would have caused this issue.
Please check your spec again.
