AutoCAD Plant 3D General DIscussion
berucheva
Message 1 of 5 (700 Views)
Isometrics in Plant 3D
700 Views, 4 Replies
09-06-2012 07:14 AM
 Help me please. Which of ISO-symbol corresponds to a 3D component CPVB000000 ?
Employee
JarrodMudford
Message 2 of 5 (636 Views)
Re: Isometrics in Plant 3D
09-08-2012 11:17 PM in reply to: berucheva
The ISO symbols are based on the SKEY. Usually a 4 letter sequence that is mapped to the block in the Iso Symbol seed file. You will also need to fill in the Iso Symbol Type field too. That will generally be "VALVE", "FLANGE" etc.
The SKEY and Type can be defined on the "General Properties" Tab of the item in the Catalog Editor. Its on the right down the bottom of all the fields. And then the SKEY can be mapped to a block in the "IsoSkeyAcadBlockMap.xml" file in the Isometric folder of your project.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
berucheva
Message 3 of 5 (599 Views)
09-11-2012 04:51 AM in reply to: JarrodMudford
Thank you for your answer.
Is there any existing SKEY for the 3D component CPVB000000 ?
Employee
JarrodMudford
Message 4 of 5 (580 Views)
09-12-2012 03:03 AM in reply to: berucheva
You can make your own to suit your needs. Usually the first 2 characters of the SKEY is the definition of the component type. ie: EL for Elbow. Then the last 2 characters for the end connections. But any combination will do. Then you can create a block for the ISO representation of the item, and map the block in xml file that was mentioned in the earlier post.
Jarrod Mudford
Global Services
Member
TONYTOMISON4872
Message 5 of 5 (499 Views)
Re: Isometrics in Plant 3D SW x THRD
10-15-2012 08:19 PM in reply to: JarrodMudford
How do you create a valve that is SW x THRD, used for drain valves.  I need to create them for GATE, GLOBE, BALL, PLUG.  And what would be their 4 SKEYname.  Is there any scale when you are creating the.  I saw the size of the GateValve & the SocketWeld and they are diffrent size.  These valves are always in sizes 1/2" thru 2" and I can't belive that they are not in the catalog already.  Any help would be great.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
