AutoCAD Plant 3D Forum
Isometrics Help!!!!!!!
7 REPLIES 7
Message 1 of 8
thebearjed
1873 Views, 7 Replies
I am losing my patience with this program. I have set the gaskets to not be dimensioned and to dimension the flanged valves to overall. for whatever reason it choses to ignore my settings...WTF??? (see screen shots)
i have to start issuing drawings very soon and i have been fighting tooth and nail with this new isometric program.
7 REPLIES 7
Message 2 of 8
in reply to: thebearjed
I've had the same problem with just about all dimensioning options in Autocad isometrics.  Another big one I have is the software dimensions my 18 1/2" end to end valve as 18'-0 1/2".  Our work around and Autodesks answer is manual manipulation.  We're looking into a separate stand alone Iso package.  We'll use Plant3D for the model and use the information to create isos with another program that is not smart and 2D.  Good Luck.
Message 3 of 8
thebearjed
wow, thats a lot of extra work to get the isos. good luck to you too.
Message 4 of 8
jenakap1
Would it be possible to attach one of the PCF files that's causing the problem?  I will ask our engineering team to take a look.  Thanks.
Pat Jenakanandhini
Product Manager
Plant Solutions - AEC
Message 5 of 8
thebearjed
in reply to: jenakap1
ISOGEN-FILES ISOCONFIG.FLS
UNITS-BORE INCH
UNITS-CO-ORDS INCH
UNITS-WEIGHT LBS
UNITS-BOLT-DIA INCH
UNITS-BOLT-LENGTH INCH
PIPELINE-REFERENCE 005
DATE-DMY 01/04/12
ATTRIBUTE1 005
ATTRIBUTE2 01SD
PROJECT-IDENTIFIER 11235
REVISION 0
AREA HP Injection Skid
PIPING-SPEC 01SH
INSULATION-SPEC
TRACING-SPEC
FLANGE
END-POINT 262.8120 43.3300 13.3125 2.0000 FL
END-POINT 260.3120 43.3300 13.3125 2.0000 BW
SKEY FLWN
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
COMPONENT-ATTRIBUTE1 SERVICE_WTR
COMPONENT-ATTRIBUTE2 INSULATIONTHICKNESS_0.5
COMPONENT-ATTRIBUTE3 BOMCOLUMN_Material_
COMPONENT-ATTRIBUTE4 BOMCOLUMN_SCHClass_150
CONTINUATION
WELD
END-POINT 260.3120 43.3300 13.3125 0.0000
SKEY WW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
CONTINUATION
PIPE
END-POINT 241.9381 43.3300 13.3125 2.0000
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
COMPONENT-ATTRIBUTE3 BOMCOLUMN_Material_SS
COMPONENT-ATTRIBUTE4 BOMCOLUMN_SCHClass_40S
CONTINUATION
WELD
END-POINT 241.9381 43.3300 13.3125 0.0000
SKEY WW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
CONTINUATION
TEE
END-POINT 239.4381 45.8300 13.3125 2.0000 BW
END-POINT 239.4381 40.8300 13.3125 2.0000 BW
CENTRE-POINT 239.4381 43.3300 13.3125
BRANCH1-POINT 241.9381 43.3300 13.3125 2.0000 BW
SKEY TEBW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
CONTINUATION
END-CONNECTION-PIPELINE
CO-ORDS 239.4381 45.8300 13.3125
PIPELINE-REFERENCE 004
END-CONNECTION-EQUIPMENT
CO-ORDS 269.8750 29.8240 21.3125
CONNECTION-REFERENCE WF-500A-N-2 150
BOLT
CO-ORDS 269.8750 43.3300 13.3125
BOLT-DIA 5/8
BOLT-ITEM-CODE 01SH-7297-3.25
ERECTION-ITEM
BOLT-QUANTITY 4
BOLT-LENGTH 3.25
BOLT
CO-ORDS 262.8750 43.3300 13.3125
BOLT-DIA 5/8
ERECTION-ITEM
BOLT-QUANTITY 4
BOLT-LENGTH 3.25
BOLT
CO-ORDS 275.4380 37.7670 13.3125
BOLT-DIA 5/8
BOLT-ITEM-CODE 01SH-7297-6
ERECTION-ITEM
BOLT-QUANTITY 4
BOLT-LENGTH 6
BOLT
BOLT-DIA 5/8
ERECTION-ITEM
BOLT-QUANTITY 4
BOLT-LENGTH 3.25
GASKET
END-POINT 262.8750 43.3300 13.3125 2.0000
ITEM-CODE 01SH-7228
ITEM-DESCRIPTION 1/16" thick 150LB flexible graphite w/ 304 or 316 SS corrugated insert, ASME B16.21
ERECTION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
VALVE
END-POINT 269.8750 43.3300 13.3125 2.0000 FL
END-POINT 262.8750 43.3300 13.3125 2.0000 FL
SKEY VBFL
ITEM-CODE 01SH-1472
ITEM-DESCRIPTION BALL VALVE 150LB RF 316 SS BODY w/ 316 SS TRIM RTFE ST, BA01ST518
ERECTION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
SPINDLE-DIRECTION SOUTH
DIRECTION SOUTH
GASKET
END-POINT 269.9380 29.8240 21.3125 2.0000
END-POINT 269.8750 29.8240 21.3125 2.0000
ITEM-CODE 01SH-7228
ERECTION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
GASKET
END-POINT 269.9380 43.3300 13.3125 2.0000
ITEM-CODE 01SH-7228
ERECTION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
FLANGE
END-POINT 269.9380 29.8240 21.3125 2.0000 FL
END-POINT 272.4380 29.8240 21.3125 2.0000 BW
SKEY FLWN
ITEM-CODE 01SH-11389
ITEM-DESCRIPTION FLANGE WN, 150 LB, RF, SS ASME B16.5, ASTM A182-F316/316L SCH 40S BORE
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
FLANGE
END-POINT 269.9380 43.3300 13.3125 2.0000 FL
END-POINT 272.4380 43.3300 13.3125 2.0000 BW
SKEY FLWN
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
ELBOW
END-POINT 275.4380 29.8240 18.3125 2.0000 BW
CENTRE-POINT 275.4380 29.8240 21.3125
SKEY ELBW
ITEM-CODE 01SH-905
ITEM-DESCRIPTION ELL 90 LR, BW, SCH 40S, ASME B16.9, SS ASTM A403-WP 316-W/316L-S
FABRICATION-ITEM
ANGLE 9000
PIPING-SPEC 01SH
TRACING-SPEC
WELD
END-POINT 272.4380 29.8240 21.3125 0.0000
SKEY WW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
WELD
END-POINT 272.4380 43.3300 13.3125 0.0000
SKEY WW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
ELBOW
END-POINT 275.4380 40.3300 13.3125 2.0000 BW
CENTRE-POINT 275.4380 43.3300 13.3125
SKEY ELBW
ITEM-CODE 01SH-905
FABRICATION-ITEM
ANGLE 9000
PIPING-SPEC 01SH
TRACING-SPEC
ELBOW
END-POINT 275.4380 29.8240 16.3125 2.0000 BW
END-POINT 275.4380 32.8240 13.3125 2.0000 BW
CENTRE-POINT 275.4380 29.8240 13.3125
SKEY ELBW
ITEM-CODE 01SH-905
FABRICATION-ITEM
ANGLE 9000
PIPING-SPEC 01SH
TRACING-SPEC
WELD
END-POINT 275.4380 29.8240 16.3125 0.0000
SKEY WW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
PIPE
ITEM-CODE 01SH-12
ITEM-DESCRIPTION PIPE SMLS SS ASTM A312-TP 316/316L SCH 40S
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
WELD
END-POINT 275.4380 29.8240 18.3125 0.0000
SKEY WW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
FLANGE
END-POINT 275.4380 35.3240 13.3125 2.0000 FL
SKEY FLWN
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
WELD
END-POINT 275.4380 32.8240 13.3125 0.0000
SKEY WW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
GASKET
END-POINT 275.4380 35.3870 13.3125 2.0000
ITEM-CODE 01SH-7228
ERECTION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
VALVE
END-POINT 275.4380 35.3870 13.3125 2.0000 FL
END-POINT 275.4380 37.7670 13.3125 2.0000 FL
SKEY CKFL
ITEM-CODE 01SH-1408
ITEM-DESCRIPTION CHECK VALVE DUAL PLT 150LB RF 316 SS BODY w/ 316 SS disc/ST WAFER, CD01ST700
ERECTION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
GASKET
END-POINT 275.4380 37.8300 13.3125 2.0000
ITEM-CODE 01SH-7228
ERECTION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
FLANGE
END-POINT 275.4380 37.8300 13.3125 2.0000 FL
SKEY FLWN
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
WELD
END-POINT 275.4380 40.3300 13.3125 0.0000
SKEY WW
FABRICATION-ITEM
PIPING-SPEC 01SH
TRACING-SPEC
MATERIALS
DESCRIPTION 0S BORE
Schedule
PressureClass 150
Material
ITEM-CODE 01SH-7228
DESCRIPTION insert, ASME B16.21
Schedule
PressureClass 150
Material
DESCRIPTION ASTM A193 Gr. B7M Bolts w/ 2 hvy hex nuts ASTM A194 2HM
Schedule
PressureClass 150
Material
ITEM-CODE 01SH-1472
DESCRIPTION 18
Schedule
PressureClass 150
Material SS
ITEM-CODE Buttweld-2
Schedule
PressureClass
Material
ITEM-CODE 01SH-905
Schedule
PressureClass
Material SS
Schedule
PressureClass 150
Material
ITEM-CODE 01SH-1408
DESCRIPTION ER, CD01ST700
Schedule
PressureClass 150
Material SS
ITEM-CODE 01SH-12
Schedule 40S
PressureClass
Material SS
Message 6 of 8
IanMatthew
Hi Jedmxr - I have looked at your problem and if I  am correct then the line size you are iso'ing is a 2" line.  If so then AutoCAD Isomentric is treating this as a small bore pipe and so the dimension style is not the default.  There are 2 ways to address this.  the quickest is to go to project properties >> Isoemtric DWG settings >> Title Block and Display and set the "Small bore piping up to and including" size down to 1" (bottom right of the dialog)
You probably also should set your Gasket Handling to "Include in component dimension"
Hope this works as you want it to
Ian Matthew
Techinal Marketing Manager, Plant Solutions
Autodesk, Inc.
Message 7 of 8
karthik.nathan
Yes it seems the piping is small bore. I believe the default dimensioning settings for small bore piping theme is overall dimensions on (and string dimensions off) with valves being dimensioned to the center. If you try changing these settings to match what you got in the default theme, you should start seeing dimensions that are how you'd expect them to be.
Hope this helps.
- Karthik
Message 8 of 8
thebearjed
in reply to: IanMatthew
that did it. thanks.
”Boost
