AutoCAD Plant 3D General DIscussion
thebearjed
Message 1 of 2 (151 Views)
Isometrics Dimensions
151 Views, 1 Replies
08-16-2012 12:36 PM
In the Project Manager under Isometrics and then Dimensions you can check the box for End to END. it says that you can OPTIONALLY STOP AT VALVES AND BRANCHES. My question is how do you tell it to stop at these points?
thebearjed
Message 2 of 2 (148 Views)
Re: Isometrics Dimensions
08-16-2012 01:22 PM in reply to: thebearjed
Figured it out. Add strinf (in red) to the IsoConfig.xml file...
<DimensionTypes>
<!-- End to End dimension -->
<!-- 'Enabled': 'true' or 'false' -->
<!-- 'StackOrder': Specfies the sequence if multiple dimension types are used.
<!-- 'FittingToFittingGasketDimension': Add an anchor point to the gasket which
is located between two fittings. e.g. flanged-valve -> gasket -> flanged-valve. -->
<DimensionType Name="Overall" Enabled="true" StackOrder="3"
FittingToFittingGasketDimension="false">
<!-- Components to exclude -->
<!-- 'Enabled': 'true' or 'false'; If 'true' the exclusion rule is enabled.
<Exclusions>
<Exclusion Name="ExcludeCap" Enabled="true" Filter="Cap" />
<Exclusion Name="ExcludeGasket" Enabled="true" Filter="Gasket" />
<Exclusion Name="ExcludeFLValve" Enabled="true" Filter="FLValve" />
</Exclusions>
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
